Catto 3 Bladed Fixed Pitch Cruise Prop
turbopilot
Last year while doing my research about buying another SS or going with an FX I was shown an FX that was built by CubCrafters to operate as an LSA with an EAB airworthiness certificate. In order to do this they had to remove the constant speed prop and prop governor from the airplane (C/S prop not allowed under LSA rules). Here is the result
This is the new Catto 3 bladed composite fixed pitch cruise prop. It weighs 16 lbs versus 13 lbs for the Catto 80" X 50" two bladed cruise prop. Both are rated at 2700 RPM full power. Both props have the same reported performance. The advantage of the 3 bladed prop is prop is that it is much shorter (4" shorter), it is smoother running and it looks much better. I order the black/white prop same as the picture though they are available in a variety of colors. Here are the details of the quote.
3-Bladed Carbon Cub 74"x50"$3,250.00T
3-Bladed Glass/Carbon Composite Propeller for Carbon Cub
74" Diameter x 50" Pitch
0-340 170+HP@2700RPM
Top Speed at Target RPM- 137-145 mph@2700-2800 RPM
3.5" Finished Propeller Thickness
7" Diameter Prop Flange
SAE-2 Pattern, 3/8" Bolts and 5/8" Lugs
Crescent Tip with Nickel Leading Edges
Color: Black with White
1 X $3,250.00
Nickel Leading Edges$750.00T
Nickel Leading Edge per edge per blade installed.
3 X $250.00
Shipping 3-Bladed$275.00
Packaging, Shipping, & Handling Charges for a 3-Bladed Propeller
1 X $275.00
Spinner 12" 3-Bladed$575.00T
Catto 12" Spinner Kit. Includes fitting of cutouts, tracking and drilling of mounting holes. Carbon Fiber Spinner with stationary self-centering front bulkhead and aluminum rear bulkhead.
Forward Facing Flange
Carbon Fiber Finish
1 X $575.00
Shipping Spinner$40.00
Packaging, Shipping & Handling Charges For Spinner Kit
1 X $40.00
Subtotal$4,890.00
Tax$400.31
Total$5,290.31
Balance due$5,290.31
